TO 30 parts question
I ordered a bunch of parts online. I still need one that I can't find. It's for a TO30. I need part number 180 062 M1. Its a tube going from the air cleaner to the carb. Any help would be greatly appreciated. I have looked at AGCO and Sparex. That number gets me nowhere, thanks John
surfman, go to tractorhouse.com, scroll to bottom. plug in part number search.
shows it is available thru reliable aftermarket parts.
(quoted from post at 11:33:08 02/15/16) I ordered a bunch of parts online. I still need one that I can't find. It's for a TO30. I need part number 180 062 M1. Its a tube going from the air cleaner to the carb. Any help would be greatly appreciated. I have looked at AGCO and Sparex. That number gets me nowhere, thanks John
Delaware, that 180062M1 part number comes up as a short piece of 1 1/2" I.D. rubber hose - is that what you need, or do you need the metal tube?
If so, the part number for the metal tube on a TO30 is 181 716 M1.
A Google search for that part number will find a used one.
I'm sorry I may need part number 825 082 M1. Number 22 in my parts book. The tractor is at my dads now so I can't look at it. Is this a metal tube or rubber? If that part is metal I'm sure it's in fine shape. I need to replace a cracked manifold and noticed the rubber hoses looked cracked and hard. It would just be best to replace all the rubber pipes to aid in install and removal. Thanks for your replys
ugh. I mean part number 181 716 M1. As you stated Tom. Is this a metal tube? Part number 12 in the parts book. Sorry the edit feature is disabled, John.
(quoted from post at 13:04:51 02/15/16) ugh. I mean part number 181 716 M1. As you stated Tom. Is this a metal tube? Part number 12 in the parts book. Sorry the edit feature is disabled, John.
John, that tube is indeed metal. It should be in good shape.
Sounds like you have the Parts Book, so you'll have the specs for those short pieces of radiator hose, but you need two (2) pieces of 1 1/2" I.D., each 2 1/2" long.
Good luck with the manifold replacement - holler if you have any questions.
Thank you for the help. Here's a few things I plan to do and have read about before I do the manifold replacement. I'll be removing the hood and tank to access the bolts easier. Rinse the tank out while its out. Clean the filter in the tank. Pull the valve cover and inspect and adjust the valve clearance. Remove the carb from manifold and leave it level and upright while the manifold is replaced. Check the manifold mating surface for major pitting especially around number 4. Deal with that issue if there is one, I've read up on that. While the hood is off I need to take the radiator to a local shop to have a side bracket re soldered. I have all new parts ordered. Studs, manifold, rubber hoses for intake, tank gaskets, radiator bushings, thermostat and hoses. What am I fogeting? Thanks,
Tom, email sent. Question, is my email always available if I would like it to be? Or do I have to put my email in every single post if I want it
available? Thanks.
One the page before this one, is the parts squares with model numbers- under fuel is this hose, $1.69.
We all have to go shopping on the YT site store, or this forum doesn't get support. There's even a few ways Canadians 'can' shop here, depends on CC's or how far from the border you are? stuff like that.
