any of you have one of these?
Speed reduction gear drive for a TO20 or TO30
I assume this is to run the 3 point hitch hay rake, would be a nice option to have for your TO20 or TO30
I understand the ground speed on my TO35 is for use with the Ferguson hay rake.
I do not know what other uses ground speed pto has other than to jack one rear wheel up and place the tractor in reverse, it will run the ground speed pto in reverse direction and unscrew the post hole digger out of the ground, if it gets hung up.
might also unplug a corn picker or baler, do not know
