ridgeracing
New User
Tractor has been running great, next day I noticed it was sputtering under load. I decided to take carb drain bolt out to drain any sediment out, hardly a drop came out. With carb drain bolt out I took petcock glass off to clean bowl and screen, re- assemble petcock, turn fuel on and no fuel goes into glass bowl! I loosen fuel line at carb and glass bowl fills up and fuel runs out fuel line at carb! But no fuel out of carb drain! Funny thing is I can start and run tractor with carb drain bowl bolt out! But runs lean at load,misses. My question is there a vent clogged in carb causing this, I am used to most auto/ cycle carbs having vents out of carb bowl etc. Shouldn't I be getting fuel running out of carb drain bolt?
