3/16 on the clutch and yank up the brake pedals, adjust the rear brakes to not turn, back off about 3 or 4 clicks. Quick and dirty clutch and brakes.
Oh. See how ya' are. Too dark and cold to go out and look at the wife's '20 so this will be from memory...or less. Clutch. You have a clutch pedal. Clutch pedal is connected to the clutch cross shaft. It is held in place with a pinch bolt. Loosen the pinch bolt that holds the pedal to the shaft. Rotate the shaft against the clutch assembly. pull the pedal back towards the pedal stop. tighten the pinch bolt. Leggo the pedal. You should have 3/16 distance from the pedal stop to the pedal. if not, redo it.
Brake pedals. Wrap a bungee cord around the pedals. Cinch them up to the steering wheel. Hope you got the rear end off the ground. Tighten the adjusters so the wheels don't turn. Back off the adjusters about 4 turns. Wheels should just turn. release bungee cords. Pedals should be at the proper height. If not, redo it.
Capeech?
Ciao!
