lower top link attachment bracket
wellmax99
Tim PloughNman Daley,
where did you buy that lower top link attachment bracket shown in the picture you posted, the one attached to the long bolt that normally attaches the sway bars
when I use my post hole digger, the top link attachment on the digger gives my top link on the tractor a fit sometimes, I do not want to ruin the draft control operation of the tractor
was thinking if I could attach the top link of all equipment I use that does not require depth control to a secondary top link like this, it would take some pressure off the normal top link
Thanks for the pictures,
Tim got back with me, said the bracket was made for the Dearborn mower therefore the bracket is narrow and most tools will not fit between bracket legs,
I may try to build a bracket myself, do not know if it would work or not,
Bob,
I will keep the picture you posted
If I do build a lower top bracket, I will use the one in the picture you posted as my pattern,
Thanks,
Fred
Hi, Some one sent me a pic of that adapter with a part number, May be a ford item?, I would like to find one myself. ......Ed
