Ambervalleyfergie
New User
Looking for some guidance if anyone can make sense out of what is happening as detailed below:
Having sorted a LOT of minor problems with my new Fergie, Im kind of stumped with this scenario..
I was told when I got the tractor that is had a short somewhere and drained the battery. I have since discovered that this is true and that the alternator isn't charging unless I fiddle. The alternator is an unknown. I have no idea what make/model as someone spray painted it grey. It has a regulator mounted to it on the outside underneath, not the back.
I worked out that the igntion light was stuffed. When I fitted a small 12v test light instead, it lights up with the key on, start the engine, it goes out and the alternator charges around 13.6 ish.
Then I started to get a different scenario. You could turn on the key, no light! And then the alternator wouldn't charge but when you turned it off, it wouldn't stop the engine unless I broke the test light connection.
Puzzled, I reconnected the light, turned on the key. And the first scenario came back. Light on, light goes out, charge, turn key, engine stops!
Anyone got any ideas on what gremlins are lurking? I figure the drain is possibly a stuffed diode in the alternator?
I had to start using another multimeter when my first went flat but gave up as the tractor sends the display haywire, especially when you connect the positive the battery (with no negative connection, and worse when both are)
Looking forward to your thoughts.
Cheers
Chris
Cheers
Chris
