SuburbanFarmer
The rear fender mounted light bulb failed. The headlight ring measures ~ 5 3/4 Inches (Stamped Pat No. 2458007 which is likely Tract-O-Light.) The GE part # is unreadable, the lens says "FOG" which for a rear work light makes sense. (Plowing snow with a rear scraper blade, particularly when pushing it backwards.)
I located a GE 4515 6 Volt which I think will work, can anyone confirm or better yet have a source or part # for a 6V sealed beam 6" fog lamp? (5 3/4")
Thanks in advance.
Thanks in advance.
