ferguson to30 exhaust valve caps
jjfest
New User
the new exhaust valves that come with the kit do not have holes for the caps. do i need them ? or can i use intake valve caps? :?
A picture
I'm looking forward to the replies. I'm to be involved with this model of an engine, summer 2016.
Thanks
Bob..
(quoted from post at 21:16:49 12/19/15) the new exhaust valves that come with the kit do not have holes for the caps. do i need them ? or can i use intake valve caps? :?
If the valves over all length is 4.079" then a cap is not required..if it measures 3.989" then it is designed for a cap. People run the short valves without caps but the short valves do not have hardened tips to handle the stress of the rocker arms pounding on them plus it throws the valve train geometry off.
Now that the head is assembled, look at the length above the retainer, compare the old valves to the new.If
the new valves are taller, they probably are designed to not have caps.
