TO35 PTO Ground speed reverse option
wellmax99
If you own a TO35 you have PTO ground speed reverse option, you might not be aware of that and hopefully you will never have to use it.
but sometimes using a Post hole digger, you get the auger caught under a root or sum such and you can not get the auger to pull out.
Option: you can jack one rear wheel of the tractor off the ground, then place the pto in ground speed, then place the tractor transmission in reverse,
when you let out on the clutch, the wheel that is off the ground will start to spin and the pto shaft will turn in reverse,
as the pto shaft turns in reverse, the post hole digger auger will reverse itself and screw itself out of the ground.
hope you never need to use this option, but it works,
guess it would work if you had a haybaler or corn picker choked up, it might work, but could mess up the knotters on a baler.
might be a bit of useless information to most folks, but who knows someone might need the option someday, I was using my post hole digger the other day and remember the option as I was drilling a hole beside an old dead tree stump, was concerned I might get it caught under a root.
I didn't know that. I have had it happen and I put pto in neutral(disengage) then use the lift but guessing it was just the red Ga. dirt had it stuck.
you are right most times it will just come out.
but I have had the blade or flutes (whatever the proper name of the auger blade) hung under a root or piece of scrap metal, and when you lift the post hole digger, the digger will not come out of the ground,
you are just stuck!!!!!!!!
on other tractors, you have to chain a pipe to the auger and man handle the auger in reverse direction to back it out or start digging. a real pain the bottom.
do not know what the ground speed pto was used for other than the Ferguson hay rake.
may have had other uses.
If you get the Auger stuck in the ground. Working in normal ground conditions, the reason is that you are not lifting and lowering often enough to keep it clear. Of course if the ground conditions are stony, then there is more chance of it digging in...
While your method of extracting the Auger does work, it isn't for just anyone to use it, you do need a little bit of knowledge and skill or there could be an accident.
The Ferguson way of extracting the Auger was to use the Plow Wrench to turn the Drive shaft, but that is on the Ferguson PHB, it wouldn't work on some newer types with a differently shaped Drive Shaft. John(UK)
