TED20 - small oil leak near lower link arm
jacka
Ferguson (year 1952). There is small oil leak near lower link arms (where links installed rear end). I don't want to rebuilb rear end (is is not necessary) so could someone tell me what is good stop oil leak stuff (according oil)?
So where is this oil leak?
(quoted from post at 08:09:21 12/18/15)
Picture 1. Oil leak is somewhere parts 21 and 22...
You have to remove the trumpets to replace those bolts. Maybe somebody else will chime in but I think it is possible to remove only one trumpet and change both sides. I'm wanting to say the left trumpet but don't hold me to that.
It may be possible to remove the PTO shaft and get in with a socket to tighten these pins but you need to know what you are doing...Sorry but the best way is to remove the trumpet housing..take the bolt out and coat the taper with a sealant and
retighten...It is possible to do both with only the left trumpet removed....
Sam
Well Sam, it isn't as easy in North America, due to the size of an average 10 year old's pudgy fat little arms, they just aren't as useful- bendable and agile as.... I better shut up, you probably have child work agencies there too...
My first of these is when I -personally- coined the phrase...
" a 3 day job for a 3 dollar part"
cause that's what it will boil down too...
