Anonymous-0
Hey guys, I've got two Z129 Engine blocks with separate issues.
1) One block is in good condition without cracks between the webs, the issue is that person that I bought if from misplaced two of the main bearing caps. One of the replacement caps looks close, the one on the end closest the flywheel will require line boring.
2) Block #2 has a hair line crack between one pair of cylinders. The crack is small, this block came with a tractor that was partially dismantled. Now I know why the tractor had been take apart. Everything else about the block is in good condition, matching caps ect.
What would you experts do with these blocks? Normally I would just toss them in the metal dumpster. If somebody can use them I'd be willing to help somebody out. Lots of you guys have been good to me over the years and I'm happy to return the favor if somebody needs one of these.
Dave Shea
Dave Shea
