soccertoad20
New User
I just replaced my entire clutch assembly on my '55 TO35. We got the tractor back together and the clutch lever didn't have enough travel to fully disengage the clutch. We adjusted it to the max and still not enough. We noticed the flywheel had been turned down and it must have been too much. We had to use the old clutch disk (didn't seem to have very much wear) because the new disk was catching on the studs that held the flywheel on. The old disk had the center rivet things ground down a little to clear the studs. Basically I need to get a new flywheel. I can't seem to find one. All I can find is the flywheel ring gear. Can anyone help find the entire flywheel assembly?
