ANY of these SEAT shall work on your TEA-20
Not all seats had hinges . Jaka , your seat is the standard agricultural Ferguson seat and appears to be in good condition . The single bolt holding the seat down is incorrect , it will also give you a sore pylly!
The mounting hole in the seat must be square , if it is not then it should be filled with some weld and filed square , this will stop the ' carriage' bolt mentioned, from turning and keep the seat square to the tractor . Don't weld the bolt onto the seat , I have seen this done and it only leads to stress cracks and failure .
http://myword.info/definition.php?id=ca_bolt_1-a
