Info found on turned crank
So this should mean that ten thou was taken off the crank rod bearing.
the crank mikes at 2.070
Add ten thou and the original crank should be 2.080 aprox. I can't find this number anywhere.
I plasti miked clearance and I have 6 thou clearance...mmm to much I think. I don't want to pull the crank just for a hobbie tractor. I'm having oil pressure isues
It means the rod and mains were turned .010 under size. If you are using a standard bearing the plasi-gage should show .010 + bearing clearance. Plasi-gage comes in different thickness ranges. Make sure you have a range that will measure over .010 clearance or you will get a faulty reading.
