markushatg
New User
Hi there.
On the inside, the pin has a cotter through it holding a nut in place.
I need to get to it, to loosen the pin so I can put a gasket under the support plate and then tighten it again. At the moment it has no gasket and the pin is so loose that it leaks from the support plate.
It's the one on the driver's right hand side, so it is reachable if I remove the PTO, but I haven't yet been able to pull out the cotter that way.
What is the easiest way to do this? Hints and advice most welcome.
