My right rear wheel went flat and was horribly dry rotted. Luckily, I found a decent replacement on CL, already mounted to a 28" 6 loop rim.
I removed the bad rear tire/wheel/all from the tractor, and managed to remove the nuts holding the inner wheel to the rim.
Now I'm trying to figure out how those 6 bolts come out of the inner wheel and the rim loops. Are they threaded, or can I just tap them back through with a hammer?
The new rim/tire has the square loops. I'm hoping I don't run into any issues remounting the inner wheel to it, but will buy new bolts if needed.
Thanks in advance.
Thanks in advance.
