Will to35 rear end fit in a 231
Probably not...I would say the shafts will be you problem. Early tractors used 6? spline shafts whilst later tractors used multi-spline(maybe 21?) shafts. what is wrong with the 231 rear end?
My old boss had a 231 that started grabbing and binding up. It was the bearings in outer end of the rear axle. Your results may very but it beats a whole axle swap.
