All,
The main reason my TO-20 is torn down, is that the water pump pulley split and I had to replace it. So decided to convert it to 12v at the same time. In searching the net for the correct replacement belt, I have come upon an issue I have not been able to solve. When trying to purchase a new belt (the old one shredded) I am finding two different belts with the same part number. One belt is 5/8 in wide and the other is 7/8 (actually 13/16 inch wide. The 5/8 fits too deep in the pulleys with barely 1/16 before it bottoms out in the pulley. The 7/8 sets too high in the pulley with about 1/8 in outside the pulley circumfrence. It looks to me that the correct belt should be 3/4 in wide. However no one seems to make a belt in that thickness. I searched the archives and did not find an answer as to which is the correct belt. Normally this would not be a problem, but my tractor has a waggner loader with the loader hydraulics driven from the front pulley. It is quite a evolution to change the fan belt. So I want to make sure the belt I install will not need replacing again anytime soon. At this time I am planning on using the wider belt figuring the wider belt will wear and settle deeper into the pulleys. Since I can not find the correct width belt,this appears to be my best option. Any reason why I should not use this approach?
