Anonymous-0
Hello, i am having trouble with my tea20 zenith carb. looking for correct starting adjustment's. there are three adjuster's on my carb. one towart the seat with a flat end on it to turn, one slot screwdriver adjuster on the front of carb(toward front of tractor) and then i have the knurled knob on bottom and toward front of tractor. I have had the tractor for years and messed around with them with no knowledge. Found in the forum's that the knurled knob should be 1 turn out for light work 2 out for heavy work, but not sure about the other 2. The tractor has been converted to 12 volt and has always had problems with spark plugs. If the thing won't start i replace plugs and then it runs good for a month or 2 i am going to go through and replace cap (hopefully i ordered the right one - lucas early type) the cap terminals on inside of cap are indented from use and not sure if spark is getting to all 4 correctly. i bought a 8n last year and neglected this thing for a while, because NATIONS STARTER AND ALTERNATOR SCREWED ME out of a starter. Ended up getting one off this site for another 300. Now i can get my baby back going. Thanks for response, I love this site.
