ardie66
New User
I have a TO 20. Below each rear axle there is a piece 5 inches long that holds the drawbar arm, I have a leak there-- the nut is off the bolt but the piece will not come off. What am I missing??
Thanks Ardie
You will have to remove axle housing (trumpet ). There is a nut inside that holds it in place. Remove wheel and bolts around rear housing, only one side at a time if both has to be repaired.
Parts Cat. pic.
Hope this sheds some light on your question
Item # 20/24
Bob...
