Greetings to all, I'm J.R. and a newbie to the tractor world. I bought a TO- 20 for a small farm-ett as my wife calls it however the HF had hydraulic issue's of not holding its setting. I tore it down and replaced sleeve, piston and rings, only to have it still leaking down. After inspection I see the fluid leaking from the sleeve. I assume it is getting by the rings on the pistons. I purched parts through yt and am wondering if I should have had it all checked by machinist for a correct fit.
Any suggestions on next path to take will be welcomed.
I'm going to pull it apart again and am looking for specs on sleeve ID, piston OD and ring numbers. Thanks in advance.
