bad monkey
Getting a little deeper into the starter problem that thus tractor had when I bought it. Seems it was wired wrong after having a starter solenoid put on it. I would like to put it back to how the factory had it. So I pulled the starter switch out to check it and I found that the rocker to engage the starter wasn't on the switch (which did test bad). I'm guessing the guy I bought it from dropped it into the trans. Has anyone ran it this before? I'm trying to fish it out with a magnetic stick. If that doesn't work can I pull the shifter to fet it or does the tractor need to be split?
