Jeremy in DE
Tractor Talk had a small discussion on 12 volt conversions. It gave me a question I'll ask here as you guys tend to be more kind and the answer will be Ferguson oriented.
Some claimed that by using a smaller capacity 12 volt battery, or by using small gauge wires, one can reduce the "kick" that 12 volt conversions have and that are hard on the starters and ring gears.
True? Or Bogus? How would I size wires? What other problems might arise if I experiment?
Though I'm no electrician, it would sound bogus to me except that some months ago I was troubleshooting a starting problem. I cleaned up the starter switch connections which were really bad. After doing so the starter certainly seemed to have a lot more aggressive "kick" and to turn the engine with more gusto. I half preferred it starting poorly but with less jolt on everything. Ideally somewhere right in the middle.
[We'll leave aside the "should it have been converted" question as it already is. And I really like the 12 volts so I can run an inverter when I'm working on some project far from the buildings.]
