My son has a TO30 with a HUPP transmission. We didn't install it, it was in the tractor when we got it. It works fine. The problem is, when you pull out and lift up on the lever, the steering arm hits the lever. I have read installation instructions for the HUPP, and "they" say heat the steering arm and pry it out about approx. 2 inches to prevent this. My questions are (1) Has anyone done this, (2) Will a propane torch get it hot enough to bend the steering arm, (3) Any chance I would break the arm, and (4) If I get it hot enough to bend, would I ruin the steering arm seal in the steering box? Thanks in advance.
