1954 TO30 Turns Over but Will Not Start
BobbyCarmon
New User
Converted My TO30 from 6v to 12v, now it will not start. Motor turns over, at the time of the change I also went back to the gear shift starter switch from a solenoid. I'm getting good gas flow from tank to carburetor. Well that's about all my trouble shooting skills that I have in this matter. Any steps that anyone can help me with would be greatly welcome.
Thanks,
Bobbycarmon
Did you put a 12-6 volt resistor in? You may have burned out the points or cool if you are running them on 12volts. Check for spark, pull a plug
and ground it with plug wire attached you should see a bright blue spark when you turn it over with ignition on. You have fuel and power
probably just no ignition.
