I have a to-30. That has been running Great. The last time is used it I was bush hogging a field with lots of thistles. It started to run hot and when I turned it off the front of the radiator was covered with white fluffy seeds. It's starts great but I was out cutting more fields and it started to get hot again.. Smoke was coming out the breather tube on the side.. And when I tried to turn off the motor it continued to run as if it was a diesel motor.
The only thing I have done since is used it last was to replace the muffler, I had knocked the back of it out, and clean front of the radiator.
Thank you
Steve a
Thank you
Steve a
