TED20 - Oil leak near oil filter
jacka
What is wrong? A small amount of motor oil spilling near to the oil filter... Bad air ventilation?
I think I would take the breather tube off the valve cover and make sure it is cleaned out really well and check the opening in the cover to make sure that is not plugged.
Thanks. I have to check it. How it should look like from the intake manifold? Is there some valve, i don't have nothing, only copper pipeline from "valvecap"? And what is diameter in the hole of manifold?
If there is only copper pipe from the manifold with no valve then this is probably causing your rough running problems
(quoted from post at 02:08:34 08/08/15)
It is just that (in my case). Where I can buy that valve (and what is that valve real official name)? Or is it ok if I put there a round metal (washer) where is a 1/8 "hole? Does it do the same thing?
It is called a breather valve , see my answer and photograph under your question about the main jet . The hole is approximately 1/16th''.
