Steve@Advance
The aftermarket tank that wouldn't fit... Well, I got it in there!
I assume it was the right tank, just an aftermarket "pretty close" replica. I say it was the tank that was off, not having an original to compare it to I really can't say.
I ended up grinding about 1/4" off the top of the front mount pads, using 1/16" rubber washers instead of 1/4", bending the cross braces under the hood up, (this has the hinged insert in the hood) to get the front of the tank low enough to clear the hood. Then shimmed the rear up an additional 1/4" to clear the throttle linkage and to get the front lower. Made a new radiator top support rod, 1/4" longer to clear the upper hose in front of the tank, put an offset in the rod to clear the tank...
Even with all this, it is still a very close fit! Going to have to check it after running it to be sure nothing is rubbing.
I went through the carb while I was there, got it running better than it has in years... The idle would not adjust, really rich, blubbering, stinking... Found the throttle shaft was worn. The minor vacuum leak must have been messing with the mixture adjustment or the atomazation of the idle fuel. Replaced the shaft, put in the rest of the kit, didn't really find anything else wrong, but it runs good now!
But... was finishing everything up, looked down, oil dripping out of the air filter bowl, rusted pin hole. So got that on order, another week delay...
Still waiting on spindle bushings, they should be here first of the week.
Got the front tires foam filled. That stuff is heavy! The wheels must weigh 75 - 100 lbs each! But no mo flats!
Almost there! Thanks everyone!
