TED20 - install engine vacuum gauge?
jacka
I want to testing my -52 Ferguson motor and carburetor. Could someone tell me, is it possible to put engine vacuum gauge somehere in Zenith 24T-2? Thanks...
I installed a new intake/exhaust manifold on my TO35.
The new manifold had a threaded hole about center of the manifold, I had to retap the
hole and insert a pipe plug as my tractor had no required piping for this hole.
However, the threaded hole would make a great place to attach a vacuum line, if you
wanted one to help adjust your carburetor.
It might be possible to brase a small metal tube onto the air intake tube, use it for
your vacuum gauge.
The plug should have been on all manifold. It was for a milking machine. I have pictures just have to find them. There is always one set up at EXPO.
Milking Machine
miner
that is exactly where the hole was on the new manifold that I bought for my tractor.
I just plugged the hold.
will be able to run my milking machine, if I ever get one.
thanks for the picture.
Well Miner, now that you found it, you better go up to my place. There's about 10 of them that haven't been milked in a month. In this weather, that must be motzarella cheese by the way out..
As far a fergie... I really wouldn't worry about vacuum pressures, just be happy it runs....
Got them milked. Got the milk cans loaded on Carry-all. Where do I take them? Oh I'll go down the road to your neighbor. She may be back home. I'll tell here you sent it.
