Trucker101
[color=black:bea3c72846]Hello all, I've been working on my 51 tea20 that has sat for a few years & I see that from the angle it was parked on that some diff fluid has leaked out . So I took the wheel & drum off to see what I could fix, well at the end of the axle there are 3 brass/bronze metal gaskets? Why 3? Every schematic that I look at only shows one? Could they be acting as shims?
Now on the wheel bearings there was no grease at all? How do you get them out? Do you have to pull the bushing or whatever it is above it & if so HOW?
Is there a torque value for for the bolts/nuts on the back of the brake backing plate? Thanks for your help.[/color:bea3c72846][size=18:bea3c72846][/size:bea3c72846]
