Trucker101
[size=18:06ff4a04b4][color=black:06ff4a04b4]Hi, I removed the starter and spun the engine over a few times to say the least, looking for the timing marks on the flywheel with no luck?!?! And I had a pin in the hole & into the flywheel. So I removed the valve cover, turned till #1 was on compression stroke & looked for the marks again, still no marks?? .. Plan B, I used a light hooked up to the coil & distributor and when I was on #1 comp TDC with a pin ti the hole & into the hole in the flywheel,I turned the dist till the light came on & locked it down there. But I just read somewhere that the timing is 29deg BTDC? So if that's correct how can I set the timing with out timing marks to go by? Or is the hole I put the pin thru set at 29deg BTDC?? And what is the correct timing degrees number??? Thanks [/color:06ff4a04b4][/size:06ff4a04b4]
[size=24:06ff4a04b4]***EDIT: I tried to edit the heading but I'm not allowed to?? Maybe a mod could fix it to "TEA20" NOT 29. Sorry for any confusion.[/size:06ff4a04b4][color=red:06ff4a04b4][/color:06ff4a04b4]
