Rick35
New User
Does a TO30 need a thermostat inline in the top radiator hose or is there one somewhere else? It is a 4cyl gas engine.
You are correct the TO 20 & TO 30 are suppose to have thermostats and yes in the top radiator hose. When you get your thermostat set it on end then look at the buldgie ring around the center, in very small letters it will tell you which way that points in the hose.
Item # 49
181 634 M1
