Delawaresurfman
Ok so I went downstate yesterday to work on my grandfathers tractor I bought. It fired right up within 8 turns of the motor. Woohoo.
There were questions that the motor may not be original.
column serial number is to 69614
Cylinder block # is 1750339M91
Block serial number is 2249
Block casting number is Z129A600N right below this number is a big zero.
On the right of the number above is B25Z
There is also a lager number 3 cast in the block under the oil fill spout at the bottom of the block by the oil pan gasket.
The tractor does have a exhaust leak at the manifold pipe conection. It has the wrong clamp. I need to get it home next weekend so I can work on it. I hope the manifold is still in good enough shape to order the tailpipe and clamp to correct this issue.
With the block casting numbers listed above along withe the serial numbers can anyone help identify the motor year, thanks John
