Troy Whittle
A couple of weeks ago, when I was mowing the field, the mow deck went to the fully up position on its own. I can use the control lever to get it to go down, but I have to manually hold it there. If I don't hold it, the lever moves to the lift position and the lift goes up.
Is there some sort of a friction plate or nut on the control arm that needs to be adjusted, or is there a problem with the 3pt lift that needs to be addressed?
