nyhillbilly
Ok, have a TO 20 with some engine issues I could use some advice. The tractor was purchased for my 9 y/o fist tractor. It runs, but lacks power. Some white smoke from exhaust. When running, it has what is best described as a hollow sounding miss, have not determined exactly where from it originates. It sounds like a backfire, but from within the engine is the best way I can describe the sound. Hoping to solve issue for him as he is anxious to use his tractor with mower and other implements, but as of now just doesn't have the power. I have replaced plugs/wires, verified they are on the proper cylinders. My choice next was either valve job or in frame overhaul unless anyone has other ideas. Money not as much an issue as time, so I would like to hit the most likely culprit first. Any advice?
