box scrapers
What size do you all use with your Fergies?
Thinking I'll use the TEF20 on it. Looking
at 4', 5', 5.5' or 6'. Going to use it to
help build a Swale to keep the food plot
drier and some landscaping around the shop.
I have an altas 6 ft for my TO35, it works good, med duty.
note diggers, there are various ways to secure the diggers, on my unit the drop in pin has a hole in the bottom of the pin, you place a locking key, this secures the digger to the machine. you want these diggers secured as you do not want to loose them in rough ground or gravel road.
you drop these diggers down and it will dig or loosen up the soil or gravel
I have three tools for leveling, each has a place.
grader blade, box blade, rock rake
I've got a 5' behind my 35.. it could handle a 6'. The 5' I barely have to take it above idle and I can pull it fully engaged and loaded. That's with loaded tires with rear wheel weights. I still run out of traction before I do power.
I pull a 6' blade behind my TO30. I have filled wheels and loader for weight. I lose traction before I lose power. I pulled all day today with mine and it works like a champ.
