Equipment: TO35 tractor, pto driven post hole digger.
Problem: Freeing a stuck post hole digger auger.
Today, a guy told me you can do the following to get a stuck post hole digger auger
freed up.
1. Jack up one rear wheel off the ground. Lock the brake on the other wheel.
2. Place the PTO lever in ground position
3. Place the gear lever in reverse, Let out clutch, he said the PTO will run backwards
and will unscrew the auger out of the ground!!!!!
Anyone know if this method would work???????
freed up.
