TO 20 Gear Oil Question
Spudm
What wt. oil goes into the steering gearbox on a TO-20 tractor, and how much does it take to fill it?
Thanks!
I saw this answer to a similar question on another forum:
{In case you needed to know what oil to put in there, it takes 80w90 gear lube just make sure that you get the right gear lube that is meant for use with bronze gears and bushings.}
I assume they mean GL-1 90 weight mineral oil like goes in the transmission, hydraulic system.
however, some of the best lube is john deere or case ih corn head grease, it is more like a heavy oil than a grease, but it has some of the best lube properties going at this time.
it also will not run out like gl-1, if you have a worn seal.
going to cost you more.
