Wider front tires
Fatjay
Anyone have any options for wider front tires? Either on the stock rims or other rims, I'd like something a bit more suitable for the type of work I do.
I have seen some tractors that are running car rims with car tires on them to not leave the marks in yards that typical tractor front tires do. Before buying different rims you want to check the offset of the center so when mounted the tire does not interfere with the steering parts.
It's a TO-30. I was thinking car tire, but wasn't sure how wide I could go on the stock rim.
I run 7.50-16s on the front of mine for a little extra floatation.
But I don't think that would quite be enough to help you out in your picture below.
If your running FEL you need flat tires. if your plowing, ribbed work better. Currently running 225/75/16 on TO-
20 stock rims. Gives about an inch, inch & half to the steering knuckle.
From the looks of your picture your front tires are fine-you need more weight on the rear tires to get you thru situations like this.
