Hi all
Ok photos of my rusty fenders, or mud guards if your an aussie.
You can see i have given them a bit of air conditioning!
The structure will be cleaned up and painted with kill rust i recon.
Then thinking of doing a fibre glass repair, either from the back or the front?? from the back will take a bit of filler.
I know welding is the best option but i do nt have one. so after the next best way that will last and not start rusing again. I still need to clean up the cuts and remove all the rust.
or get some more steel, but can i use JB weld to hold this in place?
So from reading on here that expoxy filler coating then fibre glasss is a good way to go.
What cha recon
What cha recon
