danielmccay
New User
My to30 was running just fine one day and the next it would not start. I checked and there was no spark so I replaced the coil, key switch, and plug wires. It still would not start so I replaced the wires to the coil and the key switch (they were stiff,cracked, patched and too small). I replaced them one at a time so that I would be sure to get things back in the same place. When I went to reconnect the negative battery cable the engine started turning over. Even when I disconected the wires from the key switch it still turned over. What is going on? How do I fix this?
Thanks
Thanks
