Belt Lengths on Ferguson Attachments
Believe the proper belt length on a FEO-20 sickle mower is supposed to be 92"? The old one is 91" not sure how that fitted on there.
How about the belt for the side delivery rake D-EO-20? Looks like a real pain to install, but the rake works great, going to do about 5 acres with the pair.
I believe you will find there are two different size belts for the DEO-20. There is quite a difference in the two. If you measure yours and order one they can't mix up the two sizes. Well, maybe some can. LOL
(quoted from post at 05:53:16 06/23/15) Believe the proper belt length on a FEO-20 sickle mower is supposed to be 92"? The old one is 91" not sure how that fitted on there.
There were four different length belts used on the D-EO-20 rake. Does your rake have a spring loaded idler on the belt? Earlier models had that. Also it depends on what size sheave was installed on the spider. There were three sizes available. A 15",18",22". 18" was the standard sheave. If you can tell me what size sheave you have and whether or not you have an idler pulley, I can tell you what size belt you should have. Or if the serial number is still intact on the tag,that will work too.
(quoted from post at 23:42:47 06/23/15) Thanks for the replies, it is great being able to get information from the wealth of knowledge here.
A little more information on the rake:
Serial # 8991
18" sheave and a spring loaded idler.
Try to measure your old belt just to be safe but it should be 100 7/8" belt. Part number 195433M1 or more commonly known as a C97 belt. I put one on my rake year before last. I found a NOS Goodyear C97 on ebay for $20.00.
