TO30 travel speeds
TP in IA
what are the travel speeds in each gear under-direct- over drive also what is a clean one w/ good tires 12v std size pto shaft 2 bottom plow and 6 ft rear blade worth Thankyou
It will depend on what step up and step down transmission is in it. Also it will depend on the rear tire size. If I remember right a Sherman transmission in 1st gear low range goes about 1.2 miles per hour at 1000 rpms where as in 4th gear high range will run about 22 miles an hour at 2000 rpms.
