To-20 Need a radiator shroud!
2607bkg
New User
HI, I am in need of a radiator shroud for my To-20. I have looked high and low and have talked to a parts rep with Yesterdays tractors and he says they do not make them anymore but also said that he thinks a ford 8n shroud would probably work. Any input or ideas would be greatly appreciated!
As always, Thanks in advance for the info.
Brian,
I'm sure the YT guy was trying to be helpful, Brian, but I'm pretty sure an 8N shroud won't work on a TO-20: there's just too many differences in geometry between the two.
Your best bet is probably to find someone who's parting out a TO-20/30, or check a salvage yard. There are yards in Oklahoma and Missouri, among other places, that are said to have lots of Ferguson parts, but I've never tried any of them.
By the way: what did you figure out on the "not starting warm" problem?
i have a parts TO20. I can check later today for the shroud. I can send a picture if it is there, are you still looking. I am in Mid East Mo.
Hi Tom, Thanks for the info. So what I found on the not starting problem was an overheating ignition coil, and of corse that was the last thing I replaced(spark plugs/Wires, points, condenser, rotor, distributor cap) And then the coil... but it's running like a champ now, or it will be when I can track down a radiator shroud.
Thanks again for the help
Brian,
I found the one I needed at a retired mechanic's auction, but had to buy it with an old radiator - unrepairable...$35. I have not seen another one since.
SO Thanks to "Burgh implement store" in Pennsylvania, They were parting out a To-20 I was able to track down a fan shroud for $40.00+ shipping. I didn't think to look out of state for someone parting one out so thanks for the suggestions.
