new at this, HELP!
roxi
New User
My husband just bought a Ferguson 30 TO-20. Hydraulic pump needs to be replaced, trying to find right one. Thought it was a 1950 but serial number is TO-75757 from Detroit. That would fall in 1952. Which is it please, and how do I find the right pump. One was ordered but it's the wrong one. Any help would be appreciated.
I keep finding the kits. we need the entire pump. New at this, not sure how to find right one.
The one we have is busted, can't rebuild.
You have a "1952 Ferguson TO 30" NOT a Ferguson 30 TO-20. Your best bet as far as I am concerned would be to GOOGLE Ferguson hydraulic pump assembly part number 181167M91. If you can find anyone in your area that parts out any of your "Model" of tractor (TO-30) I do not believe the year will make any difference, it is the model number you need to be correct as the TO-20 uses a different hydraulic pump part number. I would almost guarantee you no one makes these pumps now days. Also check the salvage yards. Sometimes when posting telling the area you are in can help also.
This site has a Classified ads section that might be a good place to put a free ad. Look above your post at the red line then to the left it says Classified ads. Click on that then make up your ad. I think you DO want to put your email address in the ad as it stays hidden but any person that has something you want can reach you just by clicking on your name in the ad.
(quoted from post at 18:27:53 05/30/15) My husband just bought a Ferguson 30 TO-20. Hydraulic pump needs to be replaced, trying to find right one. Thought it was a 1950 but serial number is TO-75757 from Detroit. That would fall in 1952. Which is it please, and how do I find the right pump. One was ordered but it's the wrong one. Any help would be appreciated.
The hydraulic pump out of a TO-20 will work in a TO-30. The only difference between the two was the TO-30 pump used orings on the valve chambers instead of gaskets and had an oscillator on the control valve. Most of those have long since came apart and been replaced with a control valve for a TO-20. You can even use the pump out of a 9N Ford.
OKay. got one ordered, says for a '49 but everything looked the same. If it doesn't work we'll go with the ford, no problem getting them around here.
