Tractor had not run in 5 months, started and ran for about 10 seconds, shutdown and has not started since. 12v conversion that has been
reliable for 20 years. Starter turns over with spark to each plug. Fresh fuel in carb, start fluid no effect. Replaced plugs, wires, points,
condensor, resistor. Boosted with 50 amps, pulled down gravel drive with a truck nothing... Do have suction at the carb inlet during crank.
Thanks in advance.
Thanks in advance.
