Harry Ferguson
Beert
New User
I have added a Harry Ferguson to my tractor collection.Need help identifying him.The plate in front of the steering wheel
says Harry Ferguson Serial No.TO 6929.The number does not seem to mean anything to anyone.Motor was stuck.Pulled head,
dropped pan everything good.Still stuck.Some lifter's were stuck
with rust.Took care of problem.Everything good.Now need part's.Plate on motor is Z129 329364
On the left column of YT's home page is a serial number list under 'research and info'.
TO6929 would be 1949??? a 69,29X number would be '51, which would have a 129 engine. Or there was a swap over the years.
As long as you now got it going...who cares??? Good luck with her!
You may have a combination of a TO20 & a TO30. That serial number comes back to a 1949 Ferguson TO 20 however as Steve said that is a TO30 motor. You may want to double check the serial number on the dash. The engine serial number comes back to a 1952 which would have to be a TO 30. On your dash is there a air intake screen on the right side of dash?
(quoted from post at 16:18:11 05/21/15) z-129 would indicate a TO-30.
some one else will follow with year.
Thank's for your reply.I can now get Harry back on the
road to recovery.
No screen.Left side of dash.amp guage and two switche's.
Right side.Oil guage and indicator light.
