update on to35
dahlin
Up date on my previous post on 3 point that wouldn't go down well checked hydro fluid way to much drained out about a gallon and the 3 point now works. Here is the new problem when I idle the engine down to idle it seems to load up and labors if you put the throttle higher it will chug a while then there will be a puff of black smoke and it will run fine till you idle down again. What do you think is wrong?
Wild guess would be a carburetor float with a hole in it so it won't completely shut off the fuel from the carburetor.
