flaz
New User
Hi im new to this so i hope i am doin this right i have a 52 t030 with a wagner loader and a pippen backhoe on it i was wondering if anyone had a idea about the weight of this setup i have to transport it to upstate ny and wanna make sure i get the right trailer truck combo also if anyone knows if any parts are available for the backhoe it would be a big help thanks alot for your time!!
flaz the tractor alone is around 4400 LBs and add about 1500 to 2000 LBs for the loader and about the same for the backhoe so total around 8000 to 9000 LBs would be my guess. Always better to guess high than low. I would be looking at a 10,000 Trailer (with brakes) and a 1 ton truck to pull it with.
Ypop
According to Owners Manual with fuel and lights it is 2570 just for the TO30. Then add what the loader and back hoe weigh.
thanks alot for the info really didnt quite think it would be that heavy glad i checked i am anxious to get it up there and get it workn gonna try some fluid changes and a few leaks on the pippin backhoe this weekend
Post some pictures of the hoe/loader. I'm rebuilding my oliver hoe right now and I've found out something very painful: I have hte only one in existance and there's no parts nor instructions anywhere. If you find yourself in that situation, let me know. I've learned volumes not just about my machine, but how to make due with figuring out a way to make it work when no one else has a clue.
My backhoe weighs almost as much as the rest of my tractor with loader. For that reason, I'd say you're easily north of 8-9k lbs. Chances are if it has the hoe and loader, it has something reinforcing it to make it stronger to support the weight.
also check if the tires are loaded and/or if it has wheel weights. Equipment trailers can get expensive... I have a friend that has a small transport company, and he moves my tractors for me at a reasonable rate (charges me $1 per mile).
