Ferguson To35
dahlin
Here are some pics of the Ferguson To35 I just aquired. I will need help and advice. The 3 point lifts but the arms do not want to release. I noticed the tube that the quadrant attaches to has about a 1/4 inch of movement. We have manuals on the way The serial number is 142538.
I could sure use some help with my 3 point it will go up with control lever in the down position and will not release. the plug on the top of the cover has pressure when I tried to remove it. thanks for any help you can give.Randy
You'll want to take the side cover off, the one with the dipstick in it. Just inside there are the levers that control the movement of the valve on the hydraulic pump. It's possible one of them is stuck. Don't do this with the engine running, moving parts in there!
Is there any weight on the arms when you try to lower them?
